- 7,526
- 16,720
I can only imagine the fun being had making this car....super excited for it. Hopefully tons of carbon fiber bits inside...
Logic somehow
But I think 620hp will be the correct answer plus or minus 5
The LC is certainly heavy, so I'm pretty curious to see what they come up with to shave off some of that weight.
The weight problem is the biggest issue. If Lexus can still maintain a front mid-engined rear-wheel drive layout with the large 4.0 liter sitting behind the wheels, the vehicle should plow a lot less. Michelin Pilot Sport Cup 2 tires or Pirelli P Zero Trofeo R tires are likely going to be used as well, but specially developed to be run-flats. Lexus has been adamant against offering carbon ceramic brakes, so enormous 8-piston brakes might be an option.
If Lexus is benchmarking the GTR Nismo, a car with 0-60 times of 2.8 seconds, then the LC F will be about as fast; blowing the tires off of its German rivals like the AMG GT S, the BMW M6, both the S63 and S65, as well as the RS7. At this point the LC F is running with the Porsche 911 Turbo.
Lexus has been very capable of building chassis in the past (like the GS), and we'll see if the LC F can beat the LFA (with the Nurburgring package) around Green Hell.
The problem here is that the old LFA engine lacks torque, at only 354 lb/ft.In theory, it should be the best engine possible for the LCF. 5.3 Liter stroked version of the LFA V10. It makes easily 645 - 650 HP while retaining the same HP/Liter as the LFA (116 HP/Liter for LFA and 118 HP/Liter for LFA NE). Revs up to 9500 rpm like the LFA 4.8 Liter V10.
Problem is, LCF might still be took heavy for LFA V10 since it is built for power at high revs. LCF is not supposed to be too expensive. The LFA V10 due to its exotic construction and F1 DNA (it was partly built in the Toyota F1 facility), it is too expensive to put in a car that will cost less than $150,000. Therefore, I think Lexus might be looking at putting a cheaper twin turbo V8 to get 600+ HP. That will give the low end torque a 4100 HP car needs and also the horsepower at the top end. Albeit, with much lower rev limit.
Remember here that the Germans have turbo engines. While the engines that Lexus makes produces more horsepower, without the turbos there isn't enough torque. Lexus has also placed an emphasis on making the bodies of their cars rigid; therefore making them much heavier than their German rivals. 471 hp just isn't cutting it here in a vehicle that weighs nearly 4,400 pounds.467 HP isn't enough?
The GT-R NISMO is the dumbest benchmark, much lighter, since it is a sports car, less of a GT car. The obvious benchmark should be the S 63. S65 Coupe, and the upcoming M8.
Speaking of M8, notice how the BMW M8 is probably gonna be revealed at the same time as the regular 8-Series? The 8-Series Concept was revealed at around the same time that the M8 camoflauged car was intentionally revealed by BMW. Why does Lexus wait 1-2 years after the regular model to release the F model? I hope it's just because with the RC and LC they just wanted to add it into the lineup as soon as possible and develop the F car later.
Agree with the weight. In addition, achieving under 3 second 0-60 gets increasingly more difficult with only RWD as challenges in getting all that power down to the ground increases significantly.
As for power numbers, I'm hoping to see noticeably over 600 hp (620 hp min) since nowadays these figures seem almost pedestrian (i.e. a Dodge sedan with 707 hp and Demon at 840 hp!). If the figure is 590ish, it will be disappointing regardless of performance since in this price range, "whose is bigger" matters for bragging rights.
