- 852
- 1,510
Well all of the reviews seem to be quite poor of the CVT 4 speed. The rubber band effect is still there. Also, they say the engine speed is poorly matched to the gears and still has the effect of not dropping properly when you shift to the next gear.
The 4AT in the LC500h actually works wonders to remedy the rubber band feel of the eCVT.
http://www.autoexpress.co.uk/lexus/lc/97970/new-lexus-lc-500h-2017-review
"Lexus calls it a multi-stage shift device, but does it work? Surprisingly, perhaps, yes it does. Where you used to floor the throttle and wince as the engine revs rise and stay there, the four-speed box will change down a whole gear (that means going from ninth to sixth on the ten-speed scale) and move through the gears much the same way as a traditional auto would. It even offers slightly slicker changes.
There’s still a slight hold of the revs before a ‘ratio’ is swapped, but along with a lovely engine note that’s enhanced and fed into the cabin mechanically rather than electronically. It adds to the enjoyment of the car – especially if you get a kick out of knowing how the tech is working under the skin."
