- 5,148
- 12,661
Gecko, I see it in another way. I will explain why, despite having so many setbacks, it will be a fantastic niche product, and while it may not have the "god-like status" that we would like from the new Supra, it will still be a good car.
You mention about the 415 HP Twin-Turbo V6 that they have "shelved" and have chosen a BMW motor instead. I don't think Toyota would ditch their own creation that easily to go for a BMW motor. Toyota knows what Supra enthusiasts want, and that is a Twin-Turbo I6 (not V6 or F6 or any of that jazz, simply because of the iconic Supra harmonics, sound and that certain ability to do wonders in terms of balance), RWD, a long hood and one hell of a taut chassis (the ability to tune has a factor in here too). I get it, and you're 100% right on power. It is too low for a sports car of this caliber, and to have that legendary nameplate. However, my good sir, you're not looking at the whole picture. You made an assumption how this will be around 3300 pounds. First of all, I certainly hope that does not happen. If it does, the Supra will flat out FAIL. No way will someone like Tada and Akio allow for something like this to happen. A few insiders continue to mention that at most, it will weigh a little more than 3000 pounds, and in lesser models, under 3000 pounds, which is astonishing for a sports car of this caliber. Tada was so focused on the Supra being light on its feet. If you see some of the latest videos, it actually goes really fast around the Nordschleife. Quite impressive if you ask me. An insider also mentioned that the lowest spec I6 model for the new Supra outmached the Cayman and its Z4 twin by a few seconds. Imagine the GRMN or the higher spec one. They really focused on the MkV to be more about lightweight, thanks to BMW using a newer, lighter platform, and it being hardtop. Speaking of lightweight, that is another thing that enthusiasts in general (doesn't have to be Supra followers) desire in a sports car nowadays. How about we compare power to weight ratio shall we?
If we were to compare the purported power to weight ratios then it would look something like this:
MkV Supra: 3000 lbs/335 hp = 8.9552 lbs/hp
MkIV Supra (Twin-Turbo) : 3500 lbs/320 hp = 10.9375 lbs/hp
I call that impressive.
That low weight, decent power outputs (if the 335 hp will be the only one we will be getting, which I doubt), and newer technology, these are some positives IMHO. Now for power, I think the power should be fine, when you hear about the insiders discussing about the Supra. They did remove the backseats, which ruins that grand touring nature of the Supra, but I guess they're trying to be a niche product, 2 seat sports car. You mention reliability too, do you honestly think Toyota would throw themselves down the cliff in reliability? No way (hopefully not at least)! I personally believe that is a reason why they also took a long time to release the car. Apparently, while having some similarities with the BMW engine, it should have some Toyota parts too. I could be wrong, but this is what I suspect. Also the N55 block that they would be using can handle tuning and is apparently more reliable than their other engines. Plus, if they were to build their own in-house I6 just for the Supra, with all that expectations, first of all, too much money will be spent for just one engine, one car (hopefully more), and it is just downright expensive.
There are so many other things too, but I'll leave it there. There are some negatives however.
- Most likely there won't be a manual (which was important in a Supra)
- It shares a lot of internal components with the Z4
- Interior is relatively the same as the Z4
Essentially they did re-skin the Z4 although with some original Toyota parts. That does make me a little upset. They're a gargantuan company, you'd think they would spend a little more. Although, I do think they are saving for that Gazoo Concept that they released at the Tokyo Auto Salon not that long ago. Maybe.
To close, I get it Gecko. This is our only chance to prove ourselves that we can build a 6-cylinder and or higher that is a genuine, hardcore, purposeful sports car (not counting Lexus here because they're essentially their own identity now). If we fail after all these years, the Supra, which is probably the most well known JDM car ever, will also be the same car that show the world that Toyota is a failure, in so many aspects of being genuinely sporty nowadays, also failed replicating that legendary aura like the MkIV Supra had ever again. Have high hopes that Toyota won't mess up because every time they released a sports car, while having some flaws in some terms, they were simply amazing in terms of purpose.
EDIT: P.S: The Cayman is F4 not an I4. Have a good one :thumbsup:
I agree with @ssun30's statement and I appreciate the well written reply.
However, the only reason tuners and enthusiasts loved the Supra's I6 is because the motor was able to handle many times the power it produced at OEM specs -- while still being reliable. BMW's I6s (N54, N55, not sure on B58) have proven NOT to handle high power well. Take a look through any of the BMW forums and you'll see a number of problems, not to mention the growing pains with fuel pumps and other things over the years. BMW's I6 cannot hold a candle to the 2JZ I6, and anyone who is looking to tune this car to 450+ HP will need to use a different box motor to do it. With their refusal to move away from I6s and to V6s, BMW has pretty much squeezed that engine to the brink while the 2JZ was just getting started at 320hp.
I think you're being overly optimistic about reliability as well. Do you know how many 150k-200k Supras there are on the road? How badly do you want to own a car with a BMW powertrain at 100k miles, let alone 150k or 200k? Toyota is going this route because it's an off-the-shelf strategy that is costing them very little - if you think they are reworking the powertrain for reliability, you are wrong. Toyota is CLEARLY not that invested in this car.
This car has no back seat. The same power specs it had 20 years ago. No manual. Top engine is a single turbo instead of twin turbo.
There are a million reasons why this car is really not a "Supra."
