corradoMR2
- 729
- 1,124
My guess on an RX 200t is it will be announced later this year for Australia and other markets to replace the RX 270 they currently have.
I have to admit the remote touch interface touchpad on our NX . . . even set for lowest sensitivity . . . is almost too sensitive. I am doing better with it, but it really takes getting use to. It seems Lexus may be moving away from it.
Thanks . . . I willYou can get the sensitivity customized by the dealer. Give it a shot you never know.
Thanks . . . I will
Thanks . . . I already did that. Helped a little, but not enough.You can set it yourself.
Go to SETUP on the menu, then go to GENERAL, then select FEEDBACK , you can then choose from one of 5 settings.
There is an extra "secret" way to program as well that I think Corrado is talking about. They call it "pointer speed" though, but it may be worth trying. Do these steps:Thanks . . . I already did that. Helped a little, but not enough.
PROBLEM SOLVED!!! . . . Thanks so much Onelog! . . . Corrado too!There is an extra "secret" way to program as well that I think Corrado is talking about. They call it "pointer speed" though, but it may be worth trying. Do these steps:
-Push and hold MENU and the Back arrow buttons for 5 seconds
-While continuing to hold the buttons, lightly and quickly tap the touchpad with 2 fingers. The touchpad will vibrate to confirm the setting.
-Keep pushing the buttons and repeatedly tap the touchpad to get the number of response vibrations.
-Once you get the correct amount of touchpad vibrations, release all buttons.
For Pointer Speed, the feedback vibrations are as follows:
1 vibration for slow
2 vibrations for normal(factory setting)
3 vibrations for fast
Try that out!
Sweet! Thanks to Lexus for creating the Lexus Technology Specialist position, or I probably would have never had to learn that little trick, haha.PROBLEM SOLVED!!! . . . Thanks so much Onelog! . . . Corrado too!
It was quite an aggravation, but works perfectly now.
I really appreciate everyone's help.
We have a very special community here.
Wow, love it. I noticed there is a Brake Hold button...my favorite among many features. Should be on every model.
A question: why does Lexus offer adaptive variable suspension on a given model for a few years, then delete it, then bring it back on a different model?
Also one of my favorite features, not truly necessary but a real convenience.
