It sits on the border between OEM and ODM. It seems to be based on the GAC Hyptec GT but the wheelbase and powertrain don't match up. GAC parts bin can be found in the interior (steering wheel, switch gear, dashboard). So I think GAC provided the skateboard platform, then Toyota IEM (former TMEC) integrated solutions from other suppliers to the final product (e.g. powertrain is Huawei DriveOne). So it's less "rebadge" than BZ3/BZ3X but not a Toyota-led original effort like BZ4X either.Not sure, but you need to be on LSD to think it's a improvement on looks... 😱
7ES was a design homerun!
@ssun30 is that a Toyota R&D or is it another mixed brand effort?
Well, the 7ES is the one that ranked last in its class in independently conducted safety tests in China. You can find the video I reposted on this site. Toyota is the brand that designs products for minimal regulations compliance whether they are doing ODM or OEM or vertically integrated, in China or in SEA or in NA. Remember when they cheaped out on passenger-side crash structure because IIHS only did small overlap test on the driver side?Without going too much into discussion this is all ODM stuff and Chinese marketing lives and thrives on spec sheet and no one cares if it works properly or not. I am not defending 8ES as it's probably two generations behind than BZ7 in features but BZ7 Chinese spec would never pass mandatory stuff in neither EU nor US as is. Chinese L3 has zero chance of passing EU General Safety Regulation especially when it comes to privacy, public safety etc.
At least on paper the BZ7 is not just way ahead of the 8ES, but in China it's among the most competitive at its price point. Toyota's BEV strategy in China is actually working: left other foreign brands in the dust, goes toe-to-toe with indigenous brands.
Lexus clearly didn't do their homework when researching for the Chinese market.^This is what scares me. The story was that other markets had to take the hit because this was the car China had to have... but specs are not competitive at all, and the Chinese reception seems quite cold.
Who, again, is this ES for?
Used to be available in the crown in japan until the 13th gen along with air suspension but got culled with the 14th genDamn the volvo is nice. I always said a fridge should be offered in every Lexus as an option. Such a useful option.
The new BMW i3 comes with a 108kw/h battery pack. Compared to the 77kw/h battery in the ES, a car that's a size-category above the i3. How tf did toyota fumble this so bad?
The packaging efficiency is night and day:The new BMW i3 comes with a 108kw/h battery pack. Compared to the 77kw/h battery in the ES, a car that's a size-category above the i3. How tf did toyota fumble this so bad?
ICEV 3er will be unrelated to the i3.I really hope the ICEV 3-series removes the thick floor the i3 so it doesn't look so stubby.
There are multiple reasons. From the technical side it's suspension travel. Modern BEVs are very heavy (they are roughly equivalent to a 1990s full-size BOF SUV) and the ultra low profile tires don't provide much damping. The suspension travel needs to be longer to absorb the shock otherwise you have very rough ride, hence the raised ride height.Sometimes I wonder if the raised ride height is on purpose because people want crossovers and if sedans can't beat them.... you know how it goes. New ES is basically a crossover coupe.
I3 and IX3 look almost the same height, you could even argue that the the i3 is a "coupe" version of the iX3. Or you can call the iX3 a wagon or hatchback.
8ES. For whatever reason Toyota insists that the ESU is a high-maintenance item that needs to be accessible from the engine bay, or they just did a terrible job integrating it into the battery unit (it doesn't even need to be in the housing).
i3 NA0. Still not a true skateboard architecture but I believe this is as good as you can get with a BEV/ICEV hybrid platform.
TBF the i3 is very stubby because they have a really thick battery pack. It's also 1 generation ahead of the 8ES battery so 108kWh isn't that hard in a 2900mm wheelbase. The 8ES is essentially a bZ4X sedan with updated gen-2 eAxle that Blue Nexus originally planned for 2022. 2025 should be gen-3 but that is apparently pushed back to the IS EV that will come in 2028 at the earliest. That being said, if BestCar's rendering and specs for the IS EV were true, the i3 would be in a lot of trouble.
I really hope the ICEV 3-series removes the thick floor the i3 so it doesn't look so stubby. But BMW didn't do that on the 5-series.
