Another diesel maintenance cost and complexity/reliability factor is DPF and this applies to all clean diesels engines today, not just some.
Good point on the DPF. That's a factor that is often overlooked by the auto press when speaking of diesel maintenance.
Nor do I see any mention of the purchase price premium because of higher cost for the clean diesel engine option (all).
It's true that a diesel engine, especially a turbo-diesel, is sometimes more costly to produce than an equivalent gas engine, primarily because of the alloy-metal-strength needed in the block to withstand the stress of extremely high (20:1) compression-ratios. There's also the added hardware....the DPF you mention, water-separators for the fuel, urea-tank/injection, etc.....Diesels sometimes need heavier-duty batteries and starter motors. In Lincoln's case, though, the marketers decided to give the MKZ (mid-size sedan) gas and hybrid models the exact same base price ($35,190), even though the hybrid is undoubtedly more expensive to produce. We'll see if Lexus follows suit on a diesel, although, personally, I wouldn't bet on it.
Some countries, of course, also tax diesel vehicles at a different rate than gas-engines, which can determine what the customer actually ends up paying for it. Here in the U.S., diesels often qualify for Federal alternate-fuel tax credits, which can also vary by state.
