- 854
- 1,510
Up for what? I gave you facts, I am not here to argue. Look at the specs, you don’t like the specs so you chose not to believe them. That is fine. I have other things to do on the weekend... I don’t need to put items in and take a photo, that is what specs are for. I didn’t call you a Fanboi? I said I get you are a fan of the car, no problem, just don’t make things up. I am 6 feet, 180 pounds, I sat in both. Sounds like you haven’t....
It is easy to recite internet numbers, it is another to actually prove it in real life. You are not using internet numbers when you are using it in real life. I have actually seen an M2 up-close in real life. Don't make assumptions. I KNOW RCF trunk is much bigger. Those numbers don't add up. No way in hell RCF has a smaller trunk than 2-series. You can take it to the bank. I am saying, I can prove it that RCF's trunk is much bigger than your 2-series in real life. If you are not up to back up that then let's drop this.
