MM Test-Drive: 2019 Lexus UX Hybrid AWD F-Sport
auto_car_aluminum_f_sport_fit_for_gs_is_250_300_350_emblem_decal_badge_sticker_4518910726c4ea85a17ae4a456e076b074cf0cc6.jpg
2019_lexus_ux_250h_front_three_quarter_04_d949d7a42963a7308aa5fee2ab92f4f306df66c1.jpg
Last week, I did a static review of the all-new 2019 Lexus UX subcompact (B-class) SUV/CUV., checking out a couple of versions inside and out. While there were some good features about it, I found the interior, overall, quite disappointing, poorly-designed, cramped, not really designed for persons my size, and using cheap or questionable materials. After that generally negative experience, I was not really in the mood for a test-drive, and did not want to waste the dealership's time if I was not going to recommend the vehicle or (potentially) send them any customers. So, I simply did the static-write-up (it was a thorough write-up, not just a couple of sentences or paragraphs), posted it, and that was that.
(Here's the static-review reference) (Mods.....I started a separate thread for this because I was not able to change and update the thread-title on my static-review).
https://lexusenthusiast.com/forums/threads/mm-static-review-2019-lexus-ux.4954/
Some folks, though (not just here, but other places as well) suggested that it was a mistake not to test-drive it when I had the chance, and asked me to reconsider. After about a week or so of sleeping on it, I agreed. I decided to test-drive the same version (a hybrid) I wrote about last week. The Lexus shop I was at last week, though, had sold or leased the two hybrids that had in stock (and, apparently, one of the two gas versions). Another Lexus shop, not too far away, still had a couple of hybrids left, so I hopped in my Lacrosse and drove on down while they were still available. This Lexus shop was smack in the middle of an area with quite a few poor road-surfaces, so it would also be a good basic test of the suspension and ride comfort.
One of the two hybrids available was a white F-Sport (I had not previously looked at an F-Sport, because none were available) with the all-Black NuLuxe imitation leather interior...the traditional F-Sport burgundy-red color seats, of course, are also available as an option. The F-Sport seats, of course, were a little narrower and more sharply bolstered than the standard seats, and my big rump and torso noticed it at first, but, by the end of the test-drive, had more or less gotten adapted to it, but just barely. The one I drove listed for $39,540, and included several options.
As you can see, I decided to drive the F-Sport, for several reasons. First, a number of you in the forum would probably be more interested in it than some of the other versions. Second, It had the same drivetrain, suspension, and wheels as the other versions, so it probably wouldn't make much, if any, difference in road manners. Third, I'm not sure if it was just me or not, but the F-Sport interior seemed to have some nicer-feeling trim-materials, particularly on the front door panels. The rest of the F-Sport interior, though, of course, had the same awkward control design/ergonomics as the other versions.....so there wasn't any change there. So, I checked the tire PSIs, got a test-drive plate, adjusted everything, and went off.
I have to admit that, with one major exception (the regenerative-braking system, which I'll get to later) the actual test-drive, even on the Third-World roads around that dealership, was better than I expected, and significantly better than the negative experience I had had last week on the static-review. I stayed out a little longer than usual (perhaps to make up for not doing it last week LOL)....and got a good well-rounded summary of the road manners on quite a few different concrete and asphalt road surfaces (even some smooth roads as well). I ended up actually liking its road manners a little more than the larger, more expensive NX...though neither of them, of course, can compare to the smooth, silky, refined RX, and, by Lexus standards, I wasn't impressed at all wth the NX's road manners.
Like with many hybrids, when the drivetrain system is turned on, a green READY light on the dash will tell you if and when the system is powered-up, with sufficient battery-charge, to go....otherwise the gas engine will start. If desired, again like with may hybrids, you can program the dash screen to show you which system (gas or electric) is powering which wheels, and in what percentages.....this is the only AWD system offered on the NX, as AWD is not available with the gas-engine versions. At 181 HP, this is not a particularly strong hybrid system (Toyota and Lexus don't publish most of their hybrid power-specs except for total system HP), but there is sufficient torque for most normal driving, under most conditions. The CVT (Continuously Variable Transmission) is supposedly set up to imitate a conventional automatic (with stepped-ratios) while starting out, then revert back to conventional CVT characteristics once rolling at speed. In my experience, it was pretty much seamless under most driving conditions, and you don't really notice it most of the time. There is, of course, a Sport/Manual Mode for the transmission, and manual-shifts can be done with either the shift-paddles on the steering column or with the S-mode +/- on the shift-lever, in a separate gate. An odd-looking knob that sticks out of the upper-dash, sideways, behind the steering wheel, controls the ECO and SPORT driving modes, which alter the engine and transmission response slightly (not the suspension damping). As with the new RAV-4, the rings around the speedometer and primary gauges change color with the drive-mode,
As I mentioned earlier, there were plenty of bumpy roads and street in the area I was today, and general ride comfort (always a sensitive issue in my book) was better than I expected. I think this is partly because the F-Sport version, unlike on some other Lexus products, keeps the standard (and relatively compliant) 18" 50-series wheels/tires), and partly that Lexus may (?) be responding to customer complaints that the NX's ride is too firm and noisy. Because of those complaints, they probably decided, on the UX's design, to give the suspension a little more compliance over bumps and some better sound insulation. Can't prove it, but that's my strong suspicion. Yet, in spite of the decent ride quality (for a vehicle this size), steering response is very good...quick and precise; one of the best I've seen on a crossover SUVs. The electric power steering, as with most units, filters out a bit of the road feel, but that is the case with most units. Wind-noise, from the tight-fitting door/window seals, was well-controlled. I got to sample the sound-insulation on many different road-surfaces, and, as with most vehicles, the more porous the road surface, the more tire noise, but it was tolerable and never obtrusive. Tire noise on concrete, as is also usually the case, was higher than on smooth asphalt. On smooth asphalt, it wasn't bad at all....almost as quiet as some Buicks I've tried. In the static review, I did not power up the stereo system....with the power-up, of course, that was one of the things i checked out. Once you get past the (aforementioned) awkward on/off, volume, and tuning controls, the sound quality itself was quite good.....not quite as good as the Lexus Mark Levinson units, of course, but you're not going to find a Mark Levinson option in an entry-level Lexus product. My test-vehicle had the heated steering-wheel and heated/seat options, which keep your pinkies and rump nicely toasted on a cold winter day...though temperatures at test-time today weren't too bad, only in the mid-40s.
My only significant complaint on the road-test was the regenerative braking system. Like most hybrids and pure-electrics, the UX uses a regenerative braking system that allows the free-wheeling electric motor to generate current, help recharge the battery, and act as a brake-drag on the vehicle when the accelerator pedal is lifted. The one in the UX still needs some work, and a little fine-tuning. Lifting off on the pedal, at first, doesn't produce all that much drag, then, when you push the brake pedal, you are greeted with a couple of inches of almost no-response mushiness, and then the brakes hit all at once, with much more effectiveness. I never did quite get used to it during the whole test-drive, and, IMO, is something that the engineers might have to work on a little more. I also didn't care much for the vibrating steering wheel when the Lane-Change camera thinks that you are too close to painted lane-markings. It vibro-massaged the wheel a couple of times, even when I was in the center of the lane and tracking properly. After a couple of miles of this.......(you guessed it)......I calmly switched it off, though it took some hunting through the controls to do it.
All in all, though, aside from the brakes (and the still somewhat cramped interior) a significantly more pleasant experience behind the wheel than during the unimpressive static review I had last week. If I was several inches shorter (and thinner) I could maybe live with this vehicle as a daily-driver.
And, as always..........Happy Car-Shopping.
