How much should I be expecting to spend on these repairs?
My car was working smoothly and I was shocked when my mechanic came back with all of these problems, when I left it for routine maintenance service.
How much should I be expecting to spend on these? Also how can I know these indeed need repair/replacement?
  • Wipers
  • Rear brake pads
  • highly suggest fitting brake discs also
  • Left rear shock
  • Drivebelt replacement
  • Suggest right rear shock also, good idea to do shocks in pairs
  • Wheel alignment
  • Air filter
  • A/c cleaner
  • Rear wiper
How old/high mileage is the car? Those are all regular maintenance items except for the wheel alignment, it just varies how regularly. If you're in a hot environment a lot of those things will need replacement more often than average because rubber is just that way, for instance.
