gecko
- 5,219
- 12,877
I'm going to bet all my chips on TX replacing the RX-L, as I mentioned above. But if that's the case, there's something here that bothers me and that will likely apply to the next gen RX as well: The "350" trademark.
TX 350 indicates to me that this vehicle will either be coming with the next gen 2.4L turbo 4 cyl, or a carryover GR V6 -- and if true, neither is enough. We're assuming ~300hp for that motor, and it'll probably weigh ~4,850lbs, and could have 4-5 people + their gear at any given time. A 300hp turbo 4 is not enough engine, especially when you consider the GLE 450, X5 4.0, and even the MDX coming with a 350hp turbo V6. A GR V6 is going to make roughly the same horsepower and a little less torque, so I have the same argument there again... it's not going to be enough.
TX 500h with ~350 hp will be in the sweet spot, but I really wish Lexus would call that the new "450h" because we all know it's not a true substitute for a 5.0L V8 as the naming would suggest. 350hp hybrid V6 is about what this vehicle should have, and I'm happy to see the trademark.
My theory on this is that Lexus is about to push heavy on hybridizing everything going forward, and TX 350 and RX 350 will be fairly entry level models, while things like Ultra Luxury packages and upper spec F Sport kit will probably be only available on 500h. The RX/TX 500h will likely become the core model with more options and features, and "350" will be limited to lower trims.
I do still wish there was some sort of RX 400 or 450/TX 400 or 450 trademark because I believe they need a ~375hp+ option based on the competition, likely weight and customer expectations... but I'm also expecting Lexus to lean into hybrids even harder as a differentiator, and there's nothing rumored to fill the open space between the 2.4L turbo and the V35A-FTS for gas powered cars. I think they see the 354hp "500h" as that gap filler.
