Hi
My ES 200h, european version, with Pioneer system, have this and some more problems with the audio system:
- There are almost no sound from back door speakers.
- When you are sitting at front, you will ear mainly the speaker from your side; There are not stereo sound here, unless you adjust the balance one or two point to the other side. But then the sound on the other side is worse...
- When you play disks from USB key by folder, the pioneer order it ALPHABETYCALLY based on the file name.
- When you play disks from USB key by artist/disk, the pioneer order it ALPHABETYCALLY based on the tag name of the song.
**SO it never use the tag order *** Almost any chinesse player could done this correctly. Solution: you need to edit the file NAME of every file, and the TAG name of every song..
- The system ever put a little space between songs (1 second may be). This makes me especially angry.
- If you want to explore a USB with some folders and subfolders (like /artist/album/songs.. ), you can't. It will show you all folders in a mess.
- There are a sound adjustment "Surround", but does not nothing at all.
There are other things that piss me off, like there's no voice command to cancel an active route in the nav system (my 12 years old toyota avensis have this). You have to search in the menu system with the touch pad, and push two or three "keys" to cancel route, or keep listening to the girl.
Or that the radio arranges the stations as it likes and changes them when it wants, or that when you press the "media" key then you have to select the USB again because the system does not memorize it, etc. These are things that in everyday life make it an unpleasant system to use.
The rest of the car, engine, consumption, smoothness, security systems, ever the navigation system, is fantastic to me.
The touch pad and 10" screen position is really a good option. Is really easy to use, and not very distractive, like others touch screens.
