Rear camera problem (RX400h, 2006)
Hello there
All of a sudden I had the problem that when I put it in reverse, the camera no longer shows "nicely" a picture. Please See attached pictures. It's not always the same way "limited"...
I had no accident or anything like that. Can this be a cable (loose contact)problem oret something with the fuses?
Thank you in advance.
Samet
probably the camera module failing due to a weather intrusion. Luckily these cameras are a dime a dozen, if you search the web as long as the voltage is the same as the old camera you should be able to replace it.
Did you clean the lens of the camera? Could that be the problem?
