Ehh, I have no doubt it will have the 600hp powertrain rumoured by BestCar (400hp g20e+200hp ev?) but regardless, 90k for a 4-cyl performance SUV is a joke. Mercedes realized this and switched to an i6
If you think they're putting out an RX with 600hp, I don't know what to tell you.
They're going to slap a body kit on a 400 hp RX and talk about it like it's a true performance SUV.
The RX500h F Sport Performance is a 365 horsepower 4 cylinder turbo.
The RZ600e F Sport Performance is a ~426 horsepower EV.
Both do about 4.5 seconds 0-60.
They will do the bare minimum to sell to people who want an aggressive "sporty" Lexus RX.
If you think Akio will let any Lexus model actual come to market realizing its full potential, you are quite the optimist.
The hi-po G20e top spec makes 400hp.
The electric motors currently in the RX500h makes almost 170hp.
Add in a slightly upgraded electric motor and you're at 600hp.
Trob20
While I'm not expecting it to actually bully the X5 M, the extra cooling components, upgraded exhaust system, and bigger brake package is more than they have done for any F-ish SUV before. I assume this is Lexus' compromise for not developing a production version of the LF-1 concept.
And still only produced 366 horsepower.
You could literally double the power from the electric motor(s) and you'd still be barely above 500hp.
And you're assuming a lot about the linear application of power in these systems, engineering limits, etc.
If you think the RX packaging is going to suddenly let them make this a competitive offering, again, not sure what to say.
Betting against Lexus doing a good job on a model is about the safest thing you can do these days.
Just honestly ask yourself "What is the most phone-it-in effort that could qualify for this?" and that's what they'll do.
Yeah but that was also with the underperforming 2.4T.
I definitely see them nearing 600hp with the G20e. Happy to be proven wrong though.
And no I don't think this will be a competitive offering nor there will be buyers for it, I'm just saying I think it will produce 600 or near 600hp combined output
I’m going to bet a RX600 F Sport with the 500h drivetrain, just like this RZ:
The electric motors in the RX500h are oversized. You can't add more electric power than the battery can discharge. The bipolar NiMH battery in the RX500h can "only" discharge ~70kW which is actually a lot for a hybrid battery.
To get the 200hp/150kW hybrid assist they have to use a PHEV battery that can discharge at least 150kW, which is slightly above the RAV4 PHEV. But the RAV4 PHEV added 325kg/715lbs of weight over the regular hybrid. The question isn't whether they care about the car being heavy, but how much weight the chassis could support. So to support a higher GVWR they need extra structural reinforcement, and then the weight/cost spiral begins.
They also need a full-time eAWD system that can transfer at least 100hp/75kW from the front axle to the rear eAxle, otherwise they would have terrible torque steer with 400hp driving just the front wheels. So in order to make a 450kW RX they need the 300kW ICE, a 150kW battery, a 75kW MG1, a 75kW AC-DC, a 225kW MG2 (150kW from battery + 75kW from MG1), a 225kW DC-AC, and a 11kW AC charger with optional 50kW fast DC charger. It will be one of the most complex hybrid systems ever designed on a road legal car (on the same level as the Porsche 918/Ferrari SF90). You can dream all day long but Lexus will not sell you a Porsche 918 hybrid system in a RX.
Many competitors opted for much simpler architectures compared to Toyota's very over-engineered semi-mechanical/semi-electric solution. They have 1) isolated mechanical front/electric rear axles 2) fully mechanical drive with hybrid as assist only or 3) full electric drive with ICE as generator only.
If Lexus is actually serious about this project they would simplify it into a 300hp G20E+8AT with mild hybrid assist in the front, and a 165kW rear eAxle from the BZ4X powered by the RAV4 PHEV's battery. An even simpler solution is 400hp G20E+8AT with mechanical AWD and the RX500h's 70kW MG1 and a lightweight hybrid battery with ~70kW. Either will give them a ~500hp "RX700h" within the current GVWR limit and $10k-20k in raw production cost over a basic RX350.
We have yet to see a Lexus CUV with proper stance like on F cars. RX500h has a weird stance, something is off and I cant tell what. Sure its sporty looking but something is not right. I didn't go into detail to actually figure out whats bothering me.
Anyway this smells like RZ600e and correct me if I'm wrong but so far not a single RZ600e has dropped on the streets yet. But it does look bad ass. And its like 30% more than RZ500e
My V60 T6 have this system, and it works fine.
But it has an awful efficiency and battery management... Above 120km/h it develops a drinking problem...
We recently replaced our RAV4 hybrid with the XC60 T8. Loving it so far. Plenty of power, good EV range, but hybrid mode is almost useless.
The best I've managed with our 2015 XC60 T5 was 6.2 L/100km over a 3000km road trip (most of the trip was at 4000m+ elevation, so the lack of air resistance helped). Life time average was 8.8 L/100km before I sold it. The best I've gotten so far with the T8 is 25MPG (9.4L/100km) over 250 miles, about the same as a RX350 (2.4T) I rented before. But considering that no Lexus SUV has this level of performance ever (0-100 km/h in 4.3s!), I'd call that a win.
I also considered the X5 50e but that thing is super heavy and sluggish to drive, and I've always hated German P2 PHEVs because they are even more useless in hybrid mode. I'd rather have the standard 40i, but I wanted EV mode for daily drive.
Usually I'm making around 4,5L/100km for every month doing around 4 to 5.000km, charging at home and at the office.
But the other day also did 11,6L/100km for a "faster" trip of around 400km... My 996 C4S don't use much more fuel at the same speed... 😅
  • New Optional Red Front and Rear Brake Calipers on the F SPORT Handling and Performance Grades
  • Available in Four Powertrains: 350, 350h, 450h+ and 500h F SPORT
  • 2027 Lexus RX will Arrive at Lexus Dealerships this Fall
