- 7,579
- 16,810
That front end looks amazing to me...hopefully finally with the power to match the super aggressive looks. Thank you for this info!
Agree with mike. That front end is insane... and I absolutely love it. 395hp TT V6 sounds about right too, and I assume it might be mated to the new 10AT?
Next gen F V8 is supposed to be twin turbo and 600+ hp, so I assume that the engine above would be a mid grade option.
Very promising.
Thank you for the scoop, information like this is getting very hard to come by these days, so much appreciated Carmaker1!
Not really feeling the front end personally, I both like it and hate it at the same time. Even for a GS F, I don't think it fits. I think all the black cladding looks very out of place and tacky. That rendering just looks too overdone in my opinion.
I also doubt that engine will be used for the GS F.
Also what's truly incredible is we have more details now on the next-gen GS technically, than we do on the next LS, even though the LS is coming sooner. Bizarre.
Likely with the 10 speed, but only if it is ready to be mated to the 10 speed automatic like the 2UR-GSE. This engine sounds like it is the GS300 and GS350 replacement.
The TTV8 is likely being saved for last. What will replace for 2UR-GSE for the 2019-2020 model year in the LC and LS is my question. Still a downsized, but single turbo 4.0L V8 putting out 480-500?
Then maybe the F variants get a twin turbo V8 w/600?
I have to wonder why that particular rendering was made though? Someone internally leaking hints already, but maybe too early to be concrete.
Anything is something right now.
The 2UR-GSE V8 while shockingly passed all the emission regulations, that all other automakers simply could not, was criticised by the journalists as old tech and gas guzzler. Maybe now, Toyota will give journalists what they want. But new engines will comply with higher emission standards, therefore will lose 20 percent of max hp power. Considering GS200t weight on par with GS350 I bet that weight will remain the same in this case too and maybe even Lexus will add more luxury equipment(more sound deadening material etc. Maybe Next -F will have slower pace performance than current -F, which would be ok as a result, considering the new environmental chalenges.I do however, doubt that the GS-F 2UR-GSE V8 will replaced by an engine putting out only 400 PS.
GS F cannot afford to be slower with all the competition having sub 4 second 0-60 times.The 2UR-GSE V8 while shockingly passed all the emission regulations, that all other automakers simply could not, was criticised by the journalists as old tech and gas guzzler. Maybe now, Toyota will give journalists what they want. But new engines will comply with higher emission standards, therefore will lose 20 percent of max hp power. Considering GS200t weight on par with GS350 I bet that weight will remain the same in this case too and maybe even Lexus will add more luxury equipment(more sound deadening material etc. Maybe Next -F will have slower pace performance than current -F, which would be ok as a result, considering the new environmental chalenges.
I may be one of the few that does not care for that front end...the shape of the grille looks good, the side vents look good, but those headlights and those blue things in the grille do not work for me. If the blue was blacked out in the grille, it would look good. If the headlights weren't so skinny with an overbearing checkmark DRL, then it would be perfect.
quite literally...Wanted to bump this to keep it relevant with the new engines coming and the new LS coming...the next GS will have a bigger role to fill next generation..
