2017 RX 350 F Sport - Big brake Kit
Hi, I have a 2017 RX F Sport and looking for a better front brake performance kit. Does anyone have a recommendation?
I have not able to find Big brake Kit for RX350 for some reason, like Brembo brake kits. Has anyone tried these and have any recommendations?
My OEM brakes are OK but when I brake at high speeds, I can feel the vibration.
Have you tried replacing your branding discs and pads for another brand/model?
You can choose something more performance oriented, it’s far cheaper and more than enough for the RX350...
You should also look into your actual braking system, it might be unevenly worn out or even just worn out and in this case some new OEM components will solve this issue.
With “minor” issues like this, most of the time some simple maintenance is sufficient to get it back to perfection.
